roombook areabook extension for revit 2016
Message 1 of 12
the new version is now out for several weeks and until now, 7/7/2015, there ist still no update for the roombook extension.
As mentioned in another post, we can not use the 2016 version in germany, because the areas of the rooms are calculated the wrong way.
In my eyes that is a shame for autodesk!
Come on, please release the update!
Replies (11)
Message 2 of 12
Alecb19
Hello!
About Roombook addin for Revit 2016, as Klaus said in this forum thread (Roombook for Revit 2016) we're working on them, and they'll be released as soon as possible.
Regarding the issue with the area's calculation. Could you please send us a screencast video with the behavior seen, and the steps you're going through?
Is this happening with a specifc file?
Alejandro Chinchilla
Message 3 of 12
hello,
thanks for your answer.
i added an image of a floor-plan in revit.
in germany the area in front of windows, which reach til the floor,
have to be added to the room-area, if they are deeper than 14 cm.
revit does not calculate these areas automatically.
to correct this error we need the roombook-extension.
Message 4 of 12
Alecb19
Hello!
Thanks for the reply.
Could you please provide us a sample file experiencing the issue?
Please purge unused the file in order to reduce its the size.
Best regards.
Message 5 of 12
please read my message carefully.
you can easily try that in any new or existing file.
Message 6 of 12
Alecb19
Hello!
Is this the same behavior you are experiencing? (Please see attachment)
We'd like to know if the issue is recreateable in different languages versions.
Message 7 of 12
hi,
i have to answer in german as follows:
Ich denke, Sie verstehen unser Anliegen nicht.
Wir wollen, dass Revit die Flächen richtig berechnet.
Bei bodentiefen Fenstern, also Fenstern ohne Brüstung, muss in Deutschland
die Fläche der Fensternischen mitgerechnet werden, wenn die Tiefe dieser Nischen größer als 14 cm ist.
In Revit kann ich dies ohne die Roombook-Extension nur lösen, indem ich Raumtrennungslinien zeichne
und die Wand nicht mehr als Raumbegrenzung darstelle.
Dies sollte aber standardmäßig in Revit integriert werden, oder die Roombook Extension
sollte sofort verfügbar sein, wenn jeweils eine neue Revit-Version verfügbar ist.
Wir können die Revit 2016-Version aus den oben genannten Gründen nicht verwenden, bis
die Extension verfügbar ist!
Message 8 of 12
Holger.Kloecker
Autodesk Support
Autodesk Support
Danke für Ihre Rückmeldung. Leider können wir Ihnen aktuell keine verbindliche Auskunft geben, wann die Raumbuch Erweiterung für Revit 2016 erscheinen wird. Ich kann Ihnen aber versichern, daß wir intern Ihr Feedback an das Produktteam weitergeleitet haben. Generell können Wünsche und Vorschläge für Produktänderungen, oder neue Funktionen, auf einer speziellen Produkt-Feedback Seite eingereicht werden. Die Feedback Seite findet sich hier: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794 Ich hoffe, Ihnen damit weitergeholfen zu haben.
Holger Klöcker
Message 9 of 12
hweyland
Bei uns ist die Geduld am Ende . Wir brauchen das Raumbuch, um einen Wettbewerb abzugeben und werden seit Wochen hingehalten. Mach endlich fertig das Ding !!!!!!! Hanns-Jochen Weyland Störmer Murphy and partners
Message 10 of 12
hweyland
Niemand scheint sich bei Autodesk für die Beiträge zu interressieren !! Vielen dank für nichts Hanns-Jochen Weyland Störmer Murphy and partners
Message 11 of 12
Was lange währt,....
Die Extension ist ENDLICH über die Exchange-Apps verfügbar!
Message 12 of 12
Alecb19
Hello all!
The new version of Roombook is now available.
Roombook Areabook Buildingbook 2016
Greetings!
