Title Block | Set Label Values in Project
Message 1 of 9
Good day,
Please assist:
I'm trying to set the values for shared parameter labels in a title block (Originator, Zoning, Level, Type) in a project but I can't find where to.
Refer to Sheet Details in attachment.
Connor
Replies (8)
Message 2 of 9
ennujozlagam
hello, you can try to refer to this LINK and see if helps. thanks
Message 3 of 9
Hi @ennujozlagam,
I've already created the shared parameter and added it as a label in the title block.
Please refer to image below to see how the label appears in Edit Family:
The issue occurs when I view the Title Block sheet in a project and it shows blanks, and I don't know how to change the values:
Message 4 of 9
ennujozlagam
you need to go to your shared parameters and keyin all the label you did. thanks
Message 5 of 9
ennujozlagam
post here your title block and share.txt here so we can check. thanks
Message 6 of 9
See attached.
Thank you!
Message 7 of 9
ennujozlagam
You need to click your title block so shared parameter will show up like a question mark.
or Are you referring to this? So sorry, long time never does this, almost forgotten already. please see screencast.Thanks
Message 8 of 9
The step I was missing was to go to Project Parameter > Add > then select Shared Parameter instead of the default Project Parameter.
I also learnt that you can change labels directly by clicking on them.
That's a long video - thanks for putting in all that time!
Message 9 of 9
ennujozlagam
No worries, glad to help, I need to recall everything that's the reason the video a bit long. Lol thanks Smiley Tongue
