I have a problem when loading a title block in file.
Many useful parameters ( see attach capture) may be loaded in titleblock family, but nevertheless they do not appear in file-loaded titleblock.
I am aware i should make it " Shared parameter" beforehand, however i do not find anywhere a file with this parameters, neither are they automatically linked in the file.
Any help is appreciated.
Regards, Dan
Regards, Dan
have you tried loading those same parameters into your project as a shared parameter?
does your company have a shared parameter file that everyone has access to?
are you assigning these shared parameters to SHEETS category when the option provides itself?
Thank you Toan,
Please elaborate more. I understand i must do a new file. Where from to export?
Please explain.
Thank you, Dan
Thank you Toan,
Please explain.
Thank you, Dan
If it doesn't work, share the family here.
