Title block / create custom text for manual scale parameter
efi.chantzakos
Message 1 of 10
efi.chantzakos
I have multiple views in a sheet, therefore the scale parameter says 'As indicated'.
I have created another instance parameter in order to turn off the autoscale parameter and turn on the Custom/manual scale parameter. The problem is that whatever text I type in the manual scale parameter, it applies to all my sheets that have the manual scale parameter on.
Does anyone come through this issue? what am i doing wrong? there must be something wrong on the way i create the manual scale parameter
Thank you
Replies (9)
Message 2 of 10
azad.Nanva
you should use the Instance parameter not Type parameter and dont forget you dont need to use the Share parameter.
I use the Annotation Symbol as Text box and write the my scale there.
and when i need i can use the myScaal:
I control the visibility of the my Text and Normal Scale.
if you need i can send you my Title Block.
Message 3 of 10
efi.chantzakos
Thank you for your message.
My parameter is an instance parameter. but it still doesn't work.
can you please send me your title block? 🙂
Message 4 of 10
azad.Nanva
I delete the extra information on my family:
Message 5 of 10
efi.chantzakos
is it possible to create the family in a 2022 revit version? i don't  have revit 2025
Message 6 of 10
azad.Nanva
This is 2022.
Please use " Accept as Solution"
Message 7 of 10
hmunsell
if I understand correctly, you have views of different scales in your sheet, hens the "As Indicated". But you want to type in your own scale in the scale location?
Make a shared parameter and put that in the scale location in your title block on top of the traditional Scale parameter. Then assign a visibility option to turn them on/off as needed.  See attached video on how to....
https://help.autodesk.com/view/RVT/2024/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Basic_Interac...
Howard Munsell
Message 8 of 10
efi.chantzakos
Thank you very very much. It works now!
Message 9 of 10
efi.chantzakos
YEs, exactly that. I did the other option and it works. But i will definitely try this one too. Thank you very much it is really helpful.
Message 10 of 10
hmunsell
Sounds Good. It is always good to have multiple options in your toolbelt 👍
Howard Munsell
