Good work Keith. If you use the smallest title bar button size, AND you set
Revit to "light," you can get a visual on the buttons that's not too distractingly
different. (Still not consistent the way I would like).
But if you use the "dark" for Revit, that allows the MENU bar to show up
much better, AND you have nice size buttons on your Windows title bar,
THEN you get much more inconsistency, or difference, as you can see
with the two images I posted. Either way, I would like the full consistency
IF that is possible. And that's why I'm waiting to see if anyone knows
how make Revit match the "Performance" theme like it does with the
"Areo" theme.
YES it seems like too small of an inconsistency for most Revit users to
care about, but I would like to fix it IF that is possible, IF someone comes along
and points me to a fix.
Maybe I'm too much of a perfectionist, but if I am, Revit made me
that way. I like everything perfect. I have been using Revit since version 8.
Edited by
Discussion_Admin
