Tip: How to control the render appearance of linked models
JamesC8
JamesC8
Example result:
Steps to follow:
1. Open the 'linked’ model & click on Manage Tab > Phases -
2. Create new phase after the last phase and rename it –
3. In Graphic Overrides Tab click on 3 dots next to 'Phase - Exist' -
4. Under the Appearance Tab for the 'Phase - Exist' Material you can choose a colour or add an image to control the render appearance -
5. Save & close the file.  Open the main model, select the link & click Edit Type -
6. Click 'Edit' Phase Mapping -
7. Select the new Phase that was created in the linked model -
This controls the render material of the entire link.
alan_eu
Nice out of the Box solution! I like those ones ! 😄
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
JamesC8
Thanks Alan.
Martijn.Pater
I suppose you mean to make a clay model (in realistic mode)...? 😉
Creating a "Clay Render" effect in Revit | Revit Products | Autodesk Knowledge Network
You added some steps there to linking the file, although I would suggest not nescessarily to link it to the links Phase Mapping type properties but rather setting Visibility graphics for the Link (Object Styles/Phase/Phase filter to <By Linked View ie.) Good method though... edit: using the VG settings you don't nescessarily need this additional phasing in the host model I mean...
JamesC8
If that's the correct term for it, then yes.
