Timestamp Tag
Timestamp Tag
-Navisworker-
Timestamp Tag
-Navisworker-
I'm creating interference drawings for construction coordination. Going against the grain, I've printed views instead of sheets for some overall level plans eliminating titleblocks. The only thing that I can see as as a current issue with this is that there is no way to mark a current timestamp in a view. This would require a timestamp tag. Issue is that I don't think you can create one. Maybe with Dynamo, but I don't have that kind of brain.
Instead of going nuts about my lack of standards, can anyone suggest a way to create an annotation tag that is a timestamp.
Cheers!
Accepted solutions (3)
chrisplyler
I don't have any ideas how to make Revit do it.
But some other ideas include:
Some printer drivers have the capability of adding date/time stamp info to the output. I know Brother PCL drivers do. Check your printer settings and search the internet for "time stamp" and your printer model.
Adobe has a workflow that will date/time stamp prints. Never done it myself but I read about it here:
http://smallbusiness.chron.com/print-date-time-stamps-pdf-55986.html
-Navisworker-
How did you solve it? You merely led me down the garden path away from my original question. I checked my available options and I cannot add this extra step into my work flow. I'm looking for a Revit solution and its clear you didn't provide one.
Just create a title block family with nothing except for a timestamp. Create a sheet using this titleblock and drop the view on it.
chrisplyler
Yes, I know I didn't answer your specific question. I know I did not solve it. That is evident by my having typed, "I don't have any idea...."
But I was attempting to be as helpful as I could be under the circumstances.
So don't be rude about it.
