Unrecoverable Error - only when opening one particular Sheet.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
636 Aufrufe, 3 Antworten
Hello Revit gurus!
We're getting this error for:
  • two/three users on a workshared file.
  • Some users it does not affect
  • Revit 2016 - Build: 16.0.490.0  20150714_1515(x64) (way out of date!)
  • I've reset the user - (using point 1 only from this - https://www.cadlinecommunity.co.uk/hc/en-us/articles/207488489-Revit-2016-Reset-Revit)
  • I've not reset the registry - as per the link above.
  • I've attempted a few other logical things to try and isolate the problem but I'm drawing a blank ¯\_(ツ)_/¯
I believe It may have something to do with an MEP Linked file?
I'm unsure what to do for this one - would appreciate some help :leicht_lächelndes_Gesicht:
Wayne
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
kadmonkee
als Antwort auf: Anonymous
confirm the build number is up to date with all users.
have all users exit Revit  during this process if possible.
have all users delete all local files and support folders for them
run your Revit updates
open the central file to create a new local file
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 4
als Antwort auf: kadmonkee
Thanks, Kadmonkee worked a treat!
Nachricht 4 von 4
kadmonkee
glad to hear
It happens far too often
your welcome
thank you
