Tiled wall with protruding tiles at different depths
Hello, I am quite new to revit and have managed to make a tiled wall using the curtain wall but was wondering if it's possible to change individual tiles' depths so that some are protruding out further than others to make a feature wall?
Yes. Select a tile, unpin, edit in place, and use grip to make it thicker or thinner.
This makes sense, just wondering how you select an individual tile? When i go to select it, it selects the whole thing.
tab to select.
Thank you so much, got there in the end!
On a side note, I've selected a plane and added model text but can only seem to see it in Elevation and not 3d. Have I missed a step?
