TILED FLOORS
TILED FLOORS
Message 1 of 9
TILED FLOORS
I have made a customised tiled floor and applied a hatch which represents the tiles as you can see in the pictures. But unfortunaetly the tiles dont show up at all on the floor plan. As you can see on the images everything is in the right place , I hav eset teh order of the layers correctly and applied the hatch to it as well.
Many Thanks in advance,
Replies (8)
Message 2 of 9
ennujozlagam
hi, check it here previous threads. thanks
Check HERE
Message 3 of 9
constantin.stroescu
be sure you apply a Model Pattern Type not a Drafting Pattern Type and verify if changing the scale and/or zooming the View problem persists.
Constantin Stroescu
Message 4 of 9
Thanks for your reply
I made sure that model oprtion is applied as per your advice adn teh detail level is medium , but the issue still persists and I dont see a hatch pattern.
Message 5 of 9
also with zoomin in and out the problem still exists.
Message 6 of 9
The main issue is taht my material editor doesnt have floor tiles and even when I apply material as model mode it still doesn't show it.
Message 7 of 9
As a test, try change the material to the 600x600 acoustical ceiling tile and see if the pattern shows.
Message 8 of 9
mike
I notice in the properties that the "height offset from level" is set to 0.  Firstly, if you raise the level does the hatch pattern show ?  Secondly, in the view range, does the bottom of the view range extend to below floor level ?
Message 9 of 9
Kimtaurus
Go to the view properties of the floor plan > Model Categories > Floors > Projection/Surface > Pattern Override...
Check if the patterns are set to Visible.
Note: In the Material Browser the Graphics tab defines the appearance of the material in Hidden Lines style (Surface and Cut pattern). Shading is for Shaded Views. Appearance is for Realistic or Consistent Colour Views. Changing Appearance won't change the floor in your Floor Plan as it is set to Hidden Lines.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
