tile pattern required as below image
Please provide a tile pattern as attached image staggered pattern with two different sizes
Pattycake_Kyle
@Anonymous are you are posting the forums under 2 accounts for PAT file requests?
@Anonymous
https://forums.autodesk.com/t5/revit-architecture-forum/how-to-create-two-different-size-tile-custom-hatch/m-p/9674546#M292336
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
cholden
Download the add-in pyrevit. It's free. It has a pattern creator in it along with many other goodies. Then you will be able to create any patterns you might need in the future.
hmunsell
that is a fairly  simple pattern. use a standard brick pattern like this...
     *Brick_8x8x16, Brick: Modular - 8x8x16
     ;%TYPE=MODEL
     0, 0,0, 0,8
     90, 0,0, 8,12, 8,-8
     90, 8,0, 8,12, 8,-8
And use the instruction in the front of the REVIT.PAT file to make needed changes.
Howard Munsell
