Tile Pattern - chevron 2" x 9"
Message 1 of 19
Can anyone help me create a custom .pat file for a chevron tile pattern (2" x 9")
I have written a .pat file for herringbone pattern but not sure how would a chevron work.
thank you
Accepted solutions (3)
Replies (18)
Message 2 of 19
@Anonymous Have you tried the "PyRevit" add-in? It allows you create patterns by selection. 🙂
Message 3 of 19
syman2000
Here you go. You just need to add extra Revit Parameter for Model or Drafting
Message 4 of 19
hugha
Try this, based on 9" side, 2" across, no gaps:
;        Written by HatchKit Professional
;        HatchKit Professional (c)1990-2019 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 2019-05-29
;-Time                                   : 09:04:49
;-HatchKit Version                       : 3.1.11.2776
;-HatchKit Output Filetype               : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*chevron9x2
;%TYPE=DRAFTING
135,0,0,19,-1,9,-27
90,0,0,0,12.7279221
90,-6.364,6.364,0,12.7279221
45,0,0,19,1,9,-27
hth,
Hugh Adamson
www.hatchkit.com.au
Message 5 of 19
Thank you so much, this works great.
Message 6 of 19
could you also help  create a .PAT file for a 9" x 36" staggered tile at an 45 degree angle .
Message 7 of 19
hugha
 9" x 36" staggered tile at 45 degree angle is somewhat ambiguous.
Message 8 of 19
Its a Running bond pattern.
Each tile is 9" x 36".
See attached picture. Those are 9" x 36" tiles but I need to have them staggered.
Hope I make more sense.
Message 9 of 19
hugha
That has very little to do with a thread topic regarding chevrons - and  they don't come much simpler:
;%VERSION=3.0
;%UNITS=INCH
*36x9@45
;%TYPE=MODEL
45,0,0,0,9
135,0,0,0,36
Message 10 of 19
Pattycake_Kyle
@Anonymous
Makes perfect sense! Here you go 🙂
You can rotate model patterns in Revit, so i included non-rotated and also rotated.
Non-Rotated: https://pattycake.io/pat/YlRMJNZowpA
Rotated: https://pattycake.io/pat/kRwAneZJqv3
Just click download at the top and import the PAT file into your revit.Nonrotated.JPG
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 11 of 19
@Pattycake_Kyle wrote:
@Anonymous
I think the top one is enough. Users can rotate model patterns to any given angle if they need to.
Message 12 of 19
hugha
My bad, staggered is still very simple:
;%VERSION=3.0
;%UNITS=INCH
*36x9@45staggered
;%TYPE=MODEL
45,0,0,0,9
135,0,0,0,18,9,-9
Message 13 of 19
I require a Pat file for 2 1/4" x 7 5/8" tile which is layed out horizontally on a running bond pattern.
See attached screenshot.
Thanks a lot in advance!! 🙂
Message 14 of 19
Pattycake_Kyle
PS - Next time start a new thread/post --- I think mods might get made this thread is solved twenty times over and this request isn't related to herringbone.
As requested: https://pattycake.io/pat/Xl0vgKVg6Yd
Modular: https://pattycake.io/pat/8Ge5nGGRgdl
Verify settings on the left are correct and then click download (will download a .pat automatically).
I included a 'modular' sizing --- I assume you are doing standard brick for these requested sizes? So i'd encourage you to use the modular sizes instead of the 'as requested' since this will accommodate grout thickness of 3/8" (typical). And then you wont be off several inches off over the course of the facade/wall/whatever.
These are made using our Pattycake Template/Calculators (see image, top right panel) - so you if you need to adjust the values further, create an account and enable 'pattycake pro' under settings. All free for another couple of weeks during our last stages of beta testing. If interested, use code: "sprinkles19"
ExampleAExampleA
www.pattycake.io
Message 15 of 19
zeynep3KLJ6
how do I do this for 16 x 4 ?
Message 16 of 19
hugha
Fill in this HatchKit Quickfill form:
to obtain this:
; Written by HatchKit 4 Standard Edition
; HatchKit 4 Standard Edition (c)1990-2021 Cadro Pty Ltd
;-Date : 2021-08-19
;-Time : 12:33:15
;-HatchKit 4 Version : 4.1.3.3036
;-HatchKit 4 Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*qf0,
;%TYPE=MODEL
45,0,0,19,1,9,-27
90,0,0,0,6.36396103
135,0,0,-19,1,9,-27
hth,
Hugh Adamson
www.hatchkit.com.au
Message 17 of 19
seguraaDLWP2
Community Visitor
Community Visitor
Is there a model version of this? this one is drafting.
Message 18 of 19
henryrys
Community Visitor
Community Visitor
Can you help me create the Chevron pattern 8x47 & 4x21 files? Many thanks!
Message 19 of 19
jorodriguezAPSQS
Community Visitor
Community Visitor
*PUNTA_HUNGRIA_370x160, Chevron 370x160mm a 45 grados
;%TYPE=MODEL
0, 0,0, 261.62951,226.27417, 0,-261.62951
45, 0,0, -160,160, 370,-226.27417
135, 0,0, 160,160, 370,-226.27417
