- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Context:
Residential Project.
For detail sections, I use callout views and prefer to have as little editing as possible. I also like to use material tags to identify the various parts of the wall. This is a workflow I feel makes good advantage of Revit's BIM capabilities.
In the project I'm working on, each bathroom has it's own unique tile or wainscotting etc that has varying heights. For this reason I decided to make separate wall types for finishes.
The issue is that these finish wall types force me to have something in the core of the wall. And as a result, when I need to join the tile with the adjacent wall, the tile goes all the way to the subfloor. If only I could have no core to the wall, it would behave correctly!
It seems like it's fairly common to have finish layers separate. So for those that do this method and make details, how do you deal with this join issue? Is there a solution I'm not seeing?
Some of the solutions I came up with were.
- Make the Cementitious backer board part of the finish wall (make it core, and finish layers non-core). Then remove it from the main wall. This works, however, the main wall is also related to wall types and wall legends. By removing the Backerboard it makes this method feel inelegant.
- Sandwich the finish layers into the wall. I tried this. And with my project in particular it is a nightmare. I just have too many weird situations, and when I need to make design changes it is far too cumbersome to deal with.
- Meticulously fix it in 2D by using the Cut Profile tool. For obvious reasons I would like to avoid this.
And Happy Friday!
EDIT: Added Revit Model
EDIT: Added additional text in red.
