Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
i want to print a elevation without line weight is it possible in Rivet? Wall projection line weight is too heavy in elevation i already try VG & object line style (Scale 1:100, weight -1, thick 0.0250mm) but no effect in
elevation still the same heavy thick line are visible.The attached image for your reference. The desired line weight is marked in red color, also you can see the wall projection line weight as to be heavy. Any solution for fix it..................
