Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
There is a circular chain of references among the highlighted elements.
glkirk
glkirk
This error is happening when I am merely trying to change the material of the sash on this window.
Any idea why I keep getting this error that wont let me do it?
alan_eu
Hi @glkirk
1. Did you click on the "rectangle" button or the "..." button? Click on the "..." to change the material 🙂
2. Maybe that material from another parameter. Select you family, click to edit family and find that parameter and confirm if there´s a formula to calculate this material. (send me some pics inside the family, please)
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
hmunsell
can you upload the family for us to look at?  you may have a nested family in it that has a parameter that is already being set by somthing else.
Howard Munsell
What information is being given under <Expand>.  What Elements/IDs are affected?
syman2000
I get this error message from time to time. Do you have floor, column and wall join together? If yes, unjoin them. This should fix that circular error message.
Tyler-VDCOTech
Observer
Observer
I am gettng this error when trying to upgrade a Revil file from an Architect that is still using Revit 2018 to Revit 2019.  I have Revit 2018 also and opened it successfully with audit checked.  It opens just fine in R18.  I get the circular chain of references error when I try to upgrade to 2019.
