Good day,
In autocad the hatch patern that we use is the typical wool isolation hatch.
Now I am having trouble recreating this in Revit.
I downloaded a pat file that I have found in previous posts and forums which looks like the one I need, but I am having trouble adding it nicely. It doesn't scale well and I cannot get it aligned well either.
Besides this it doesn't rotate both ways, as in AutoCAD.
Any tips?
Gelöst! Gehe zur Lösung
Gelöst von alan_eu. Gehe zur Lösung
The best way I found to import hatches from Autocad is:
Now on, that hatch will be aided in your list.
personally i don't like bringing in AutoCAD content if i don't have to. you can copy the AutoCAD hatch pattern and do a quick edit to make it compatible with Revit.
Copy the pattern file from AutoCAD, rename it and add ;%TYPE=DRAFTING or ;%TYPE=MODEL just below the description of the pattern. this will define if it will work as a Drafting pattern or a Model pattern, or both. the image below is from a Brick pattern but shows where to edit the .PAT file.
Howard Munsell
