The walls keep connecting even though i have placed a column in between
nicol_mukaj
nicol_mukaj
Hello to everyone. I have created the walls and the column in between but the cut pattern of the walls keeps connecting, plus i have fixed the cut pattern of the column in the visibility graphics but when i connected the columns to all the levels their pattern dissapeared.
Disallow Wall Auto Join.  Also, open Column Family and uncheck "Automatically Join Geometry to Walls" to prevent the Column from auto joining in the future.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
nicol_mukaj
the cut pattern of the column in the base level looks correct but in the other levels it just goes blank.
Could be a number of reasons why. Post your File.
nicol_mukaj
Beside this problem I don't know why does the wall line appear black when I set it to a different color as you will see in the file I uploaded13.PNG
I don't find any issues. Your Columns do have a Coarse Fill Color/Pattern, and the Views shown in your above 2 screenshots of "Level 0"  are set to different Detail Levels. One is set to Coarse and the other is not.  Get it?
nicol_mukaj
Thank you, I am very new to Revit 🙂
