The mass are not visible
...is the Category turned on under VGOs?
syman2000
Go to Visibility and Graphics and turn on MASS. It is off by default.
RDAOU
@Anonymous
From the look at the Ribbon...it appears you are trying to run a analysis using Conceptual Mass. For 1, The building in the image you have posted does not look like a conceptual mass;
  1. either create one
  2. or run the analysis using building elements Energy Analysis using Building Elements - Quick Start | Revit Products | Autodesk Knowledge Network
Energy Analysis using Conceptual Masses - Enable the Energy Model | Revit Products | Autodesk Knowledge Network
Type a product name
