The Custom Revit "Project Information" Parameteres not showing in Navisworks!!
spahlevan
spahlevan
I have created many custom parameters for a REVIT template but some are assigned only to the "project Information" CATEGORY (see the images below) hence they will be filled only with the general information about the model.
The exported IFC (the extention required by client), loaded it to the Navisworks, as the result all those custom parameters (assigned to different categories such as Walls, Floors etc.) are present in Navisworks except the specific ones assigned to the "Project Information category" are not shown anywhere!!
additional note: I looked into the IFC code and guess what, they are there!!!
I have attached some images to get the idea how I assign the parameters. If any more information needed please let me know to provide.
Looking forward for a help!
Cheers.
Works here.
IFC Export settings:
In Revit
In Navisworks
spahlevan
@ToanDN thanks for the reply!
I am using the same "IFC Export settings".
Are you selecting the IFC file itself or other sub elements to see this information (from the Navisworks Selection Tree)?
Thanks!
spahlevan
Fantastic, Thank you!
@ToanDN I noticed you have more options in your export panel. What is your IFC type / version?
spahlevan
Hi, what is your Navisworks Version and type? seems we can not see these infos in all versions!!
