Texture editor
4 REPLIES 4
710 Views, 4 Replies
Texture editor
On my texture editor when I try to resize a image iam not given the option to. The only options I have are sample size, and glossyness,and type..there is no further option to try and edit the texture.
Texture editor
4 REPLIES 4
L.Maas
L.Maas
The size of the texture in the editor is determing by the sample size
If you unlink the width and height you can resize the texture. I checked your image and it is 600x800 pixels.
I translated this into sample size of 300mm and 400 mm (to maintain aspect ratio).
So in this case the texture will be tiled on your material where each piece 300x400mm.
If you want to do more to the texture you should open the picture in an image editor (e.g. photoshop, gimp) and modify it in there.
Louis
Please mention Revit version, especially when uploading Revit files.
Louis
in reply to: L.Maas
Hi..thanks for the reply. But I have messed with those already and they make it huge in the rendering..Kinda like gigantic wood rings..Ive seen in the texture editor before where you have options to rescale it on the y,z, axes and such..Why dont I have that option?
like this image:
Also, they are tiling and the image is seemless...so what can I do?
like this image:
L.Maas
L.Maas
Look at your sample size. Probably still a setting not correct?
Above is material applied to a wall.
Do I understand correctly that you want the material to be seamless? If so than you have to use other software (e.g Photoshop, Gimp) to make the texture seamless or you wil have to look for seamless images. Search the internet for seamless pictures or depending on your image software look for tutorials on how to make them yourself.
Louis
Louis
