Texture alignment pattern not visible in Material Browser
Does anyone know why for some materials the texture alignment pattern/grid is not showing in the material browser?
I have tried modifying the color, the pattern, also turning off the render appearance, changing the shading color and transparency, but all to no effect.
The strange thing is that the surface pattern displays as it should in the model, but I cannot move or align it like I would with other "working" materials/textures.
Thank you
It only works with model patterns, not drafting patterns.
