Text Space Issue when ploting
I have an issue when i try to plot any view.
The letters get so close when printed, does anyone knows how to solve this issue?
I leave a picture of how the views are plotted and how its supposed to be.
It happens with any font, on any printer (pdf or physical)
I checked the printers settings also.
My PC specs:
CPU: Athlon 200ge
RAM: 16 gb
GPU: Radeon Vega 3 (cpu integrated)
Windows 10
Thank you
* I'm not english native speaker, sorry if i misspelled something
francfiles
I assume it depends on the font style you are using. For example, when you use a roman text in Revit, it doesn't print very well whereas using an Arial text does.
Thanks, but i'm using Arial (the pictures text is arial).
syman2000
Do you know which PDF writer you are using? Adobe, CutePDF, Bluebeam?
francfiles
We're using the same font style. I'm assuming it's your plotter that is the problem.
It wasn't the pdf plotter nor the font type, it was the gpu or the graphics driver of AMD.
I installed a GTX 1050 and its solved.
