text size changes
text size changes
noconnorG728Y
text size changes
noconnorG728Y
I have an issue with changing the Text size with leader. When I changed the size from 1.5mm to 2mm, the leaders get messed up. Straight leader to crooked leader. See image.
Is there a way to stop this from happening? TIA
vitorbortoncello
 individually remove and add new leader to realign
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
jay_colc
This is due to the Text Alignment and the start of the leader having no real association unlike AutoCAD so when the Text Height is increased/decreased the Leader line moves with the Text position but the Arrow head node does not!
2025 has a new tool for such issues
Help | Multiple Alignment | Autodesk
Jay Colcombe
Autodesk Certified Instructor
