Text Rotated inside Elevation Tag Symbol
The text inside my elevation tag is Rotated on its side. I am not sure how this happened and I have looked through many forums to attempt to change it without success.
Any thoughts?
Sahay_R
Locate the family on the Project Browser. Right click on it, and click Edit. This will take you to the family.
Once in the family, window select whatever you see and rotate it through 90 degrees. Load it into your project. That should fix it.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Does it happen everywhere or just for certain views?
Its show in all views that its located. I currently have it on my first and second floor plans.
