Text on detail element is not exporting to DWG
alejandro
Message 1 of 13
alejandro
Hi everyone,
I have a family (Detail Element) witn a nested Generic Annotation to read a parameter, it seems very stupid family, but our client needs the dimensions with a formula (driven with a strange rules), we can´t use revit dimensions.
the problem is this text is shown correct in revit, and also export to pdf, but in many views -not all- when exporting to DWG the text is not visible.
I atached some screenshots, may be more easy to explain.
 thanks in adavance,
Replies (12)
Message 2 of 13
ncoutts
Seems like a scaling issue to me. When exporting from Revit the scale is always 1:1. You might want to check the AutoCAD file you are importing into. Be sure the drawing units are the same as they were in the Revit file e.g. mm to mm or decimal feet to decimal feet.
Message 3 of 13
alejandro
The units are the same,  although I have two diferents views in the same sheet when exporting one view is correct and the other is without texts.
Message 4 of 13
ennujozlagam
have you check the autocad layer it could be off/freeze or share some part plan here so we can check. thanks
Message 5 of 13
ncoutts
What happens if you use the export setting "Export views on sheets and links as external references" ?
Or do you already have that checked?
Message 6 of 13
alejandro
All layers on,
In the jpg atacched you could see in autocad the floorplan from one view is ok , but the other not. , same autocad drawing, same view template in Revit, also in PDF  in both i can see the text
Message 7 of 13
alejandro
I´ve tried both, exporting with  "export views…."  and without and get the same result ,
In the same autocad file I can see the text from some views but not from others…  see jpg attached
Message 8 of 13
ennujozlagam
if possible i need a revit file to explore on how to solve the issue. in jpeg file i cannot do anything just look at it. just saying. thanks
Message 9 of 13
alejandro
I´ve tried to send you a private message , but I can´t  "you reached the maximun number of private message"
How I can send the model?
Message 10 of 13
ennujozlagam
you can use dropbox or gmail and share the link. thanks
Message 11 of 13
ennujozlagam
You can try to send the message again, sorry for that, so many queries received. Just cleared everything, thanks
Message 12 of 13
ennujozlagam
I'm not sure if this is you wanted it to be, I exported to DWG and find no issue's text is there? Have you tried to install the latest updates from Autodesk, autocad and revit? And see if helps. Please see screencast. Thanks
Message 13 of 13
alejandro
Thank you! I reopened the project in REVIT 2020 (originally was 2019) and still have the export issue, now upgrading Autocad and Revit version with the latest Upgrades and Fixes I wish I´ll been more lucky.
