text notes
text notes
Message 1 of 9
text notes
text notes in view looking good and sharp do not appear correct in PDF-prints (letters look expanded and run into each other) ;
(working with Revit Lt 2018 in windows 10 environment on bootcamp iMac computer)
Replies (8)
Message 2 of 9
kadmonkee
try changing the font to something similar looking
is it a true type (ttf) or Shape  (shx)
what are you using to create the pdf , is the font embedded in the software?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 9
true type fonts ; even print preview does not look okay. DPI settings, display scaling, nothing helps....
Message 4 of 9
-FDC-
Can you post a screenshot ?
Message 5 of 9
Try turn off Hardware Acceleration, restart Revit and Print Preview.
Message 6 of 9
screenshot attached : some text is looking good (room tags) , other completely blurred... deactivating hardware acceleration does not help either.
Message 7 of 9
-FDC-
You probably used a font that isn't pdf compatible.
What happens if you change the font to Arial ?
Message 8 of 9
In example view all  text is Arial ; some look good  , some not .... changing to other fonts changes nothing.
Windows 10 does not seem to remember earlier settings ?
Message 9 of 9
-FDC-
Can you post or mail the drawing so I can check it?
