Text Issues
Text Issues
Text Issues
When I open a drawing in 2017 from an older version the text appears larger an overlap in title block.
Can anyone explain how to fix this?
This is a problem in Revit 2017 but I heard it is already fixed with the 2017.2 update. Have you tried to update Revit?
I haven't updated to 2017.2 myself so I am still having the same problem. I had to reduce the text size to a tad smaller, e.g 1/8" text is changed to 15/128".
I think you should update Revit first see if it can fix your text.
Darin.Green
@Anonymous
Apply the latest update for Revit. That should fix it.
If this information was helpful, please consider using the Accept Solution
Darin.Green
@Anonymous
Before you apply the update, take a look a this thread. That way you're aware of some things that could be effected by updating Revit.
