Text field in Draft view
morris_duncan
morris_duncan
Hello Group.
I´m wondering how can I insert a text field that "calls" automatically the saved file path of my current proyect. Something like in Autocad with MT > right click > insert field...
jay_colcombe
There is a way but is an only be placed on Sheet Views - I would recommend creating a Generic Annotation Family and set the Family Category & Parameter's to Title Block
Then Create a Label > pick the  File Path Parameter
File Save As > Load into Project
Many have this added to their Title Block already when loaded into Revit.
Alternatively you could create a Shared Parameter and call out this Field and add other Categories
Jay Colcombe
Autodesk Certified Instructor
morris_duncan
Well maybe I can use this as a solution.
But it would be perfect if it could be in Draft view.
Thnx any way
RLY_15
What would be your purpose for having it available in Draft view?
morris_duncan
Having a Fronpage with the file data to locate the correct file because we use similar files to work
