Text and tags not visible in callout view, which one I have to toggle in the ..
1. Text and tags not visible in callout view, which one I have to toggle in the visibility settings. They are all toggled on.
2. How to change the arrow of the tags?
3. How to make one line through the object, place text and position dots on the places where the line and the materials cross? This in order to indicate the materials with the text.
Alfredo_Medina
Callouts have an annotation area around the crop region. If the space between the edge of the crop region and the annotation region is too narrow, the text notes and other elements don't have enough room to show up.
About arrowheads, check the type properties of your annotation element.
1. They maybe outside of the Annotation Crop.
2. Edit Tag type and select a different Arrow head.
3. Sounds like a Material Tag. Have you tried that?
Thanks Alfredo!
ToanDN, is it possible to tag materials in one line?
And how to change the material name, because I am not using 'Soda Lime Glass'. I am using 'Structural Glass 150mm'.
Assuming I understand you correctly, edit the Material Tag family and stretch the label so that a long name can fit in one line.
Open the Material Settings, go to Identity tab, and change the Description.
More like this. Is this also possible? Marking the materials in one line.
