Tensile windsail
Tensile windsail
Message 1 of 10
Tensile windsail
Trying to create a windsail tensile structure and struggling to get a refined control for the tension curve fits on the sides.
Added some voids to cut out the curved shape but while flexing the family to some extremes it fails to reproduce acceptable results.
Any ideas on how could I create the curved edges w/o using the Void?
File also attached.
J
Replies (9)
Message 2 of 10
cbcarch
Looks like you are in the Conceptual Modeling (Massing) environment?
Try using arcs or splines thru points to define the shape, then "create form", instead of trying to cut the curves out using voids.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 10
thanks @cbcarch
I tried using arcs first but it just triangulates the whole thing. The goal is to have a smooth curved surface.Tensile using curves.png
Message 4 of 10
cbcarch
take a look here:
https://www.youtube.com/watch?v=9_jJBtKGLyc
Cliff B. Collins
Message 5 of 10
Thank video is useful, but I wanted to create an Adaptive Component that looks the same as the Mass family shown.
I can create the 3 RefLines through points and I get the shape I need. I am looking for ways on how to control it with the curved edges.
Message 6 of 10
cbcarch
In the AC family, try using Reference Lines, with angular dimensions associated to them, and set parameters.
Cliff B. Collins
Message 7 of 10
Shouldn't the edges be straight because of the tension force?  At least keep two opposite edges straight then the form will stay smooth.
Message 8 of 10
@ToanDN, I do not think the edges will be straight due to the elasticity of the real fabric material.
@cbcarch, not entirely clear on what you mean on "try using Reference Lines, with angular dimensions associated to them, and set parameters."
Message 9 of 10
Make it as a mass with 2 straight edges so that the surface is smooth.  Then place a roof by face and use vertical opening to cut the straight edges to curves.  Revit 2017 file attached.
Message 10 of 10
FAIR59
you can create the sail using 3 splines.
  • First find the mid-point of the sail (point halfway on red line.
  • Create spline from midpoint edge - midpoint sail - midpoint edge (yellow line in the middle)
  • Create sail using the 3 yellow splines
