Temporary Dimensions
joe-2020
joe-2020
I am having trouble with temporary dimensions. They show up when I select a wall, but not when I select an opening (such as a door, window, etc.). Also, I am unable to change the location of openings using non-temporary dimensions (Like when you select a window/door and it allows you to define a distance on a dimension you created with the "aligned" tool). All this is making it difficult to change the location of an window/door once it is placed. The only way I can seem to do it is with the EQ function , or just slecting the item and manually moving it with my mouse and guessing at distances.
Place actual dimensions so that you have controls over where it measure from and to, then select the element, not the dimension, and the dimension text will turn blue, click on the text to edit to adjust the element location.
joe-2020
Thank you very much 😁
