hi
You can Temporary Dimension We set When the We choose Wall Back to back Be displayed.
( Not to be manually Drag it to a solid blue It automatically )
I do not believe that this is possible to set automatically. If one sets the Temporary Dimensions to measure from the Wall Faces, it will place a Temporary Dimension to measure between the nearest Wall Face as depicted in your image. You'll have to continue to drag and reassign the witness lines manually to achieve your goal, unfortunately.
Yes you are right
However, we need Sometimes the As temporary Dimension The exterior walls face And sometimes internal wall face.
Such as set is Temporary Dimension doors and windows.
