Template for object in Revit
Hello everyone. Should I use a basic construction template to draw a lamp project that I am working on or use the mechanical template instead?
Lamp project?  Do you mean a lighting fixture or a lighting design for a building?  If a fixture, use Lighting Family template.  If a lighting design for a building, use Electrical Project Template or System Project Template.
hello, yes a lightning fixture but for a park.
Then use the Lighting Fixture family template. Place it in a park then it is for the park, place it in a garden then it is for the garden.
ok sounds good. I  will try that then
