Temp Dimension Per Object Selection
tim_crouse
Message 1 of 11
tim_crouse
I am not understanding why the selection of a verical wall section brings up a horizontal temp dimension or vice versa.
Selection of a horizontal wall brings up a vertical temp dimension.
What is the proper technique to select a vertical wall and have the vertical temp dimension appear?
Tim
Replies (10)
Message 2 of 11
Message 3 of 11
tim_crouse
See attached image for behavior I am trying to explain.
Message 4 of 11
The dimension indicate the location of the selected element relates to another element in the close proximity. Why is it wrong?
Message 5 of 11
It looks wrong to me, but not the way you mean. I would expect a string of vertical dimensions.  Not Horizontal.
...looks like I'd be disappointed too.  No string.
Message 6 of 11
String happens.
Message 7 of 11
Yeah; same here on that side.
Maybe I ought to open a support case?  😉
Message 8 of 11
tim_crouse
So I guess the approach is to click the object you want to set the length of and if the wrong temp dimension appears you click on nearby perpendicular objects until the correct temp dimension appears.
I guess I was expecting the temp dimension to be in the orientation of the selected object.
Tim
Message 10 of 11
Temporary dimensions prioritize the location of the selected element.  Only when it does not find any relationship location wise, it shows the element dimension.  So if you have only a wall in the view, nothing else, then when you select the wall, the temp dim is the length of the wall.
Message 11 of 11
Learn to love it.  It is what it is.
