- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Autodesk forum!
Currently working on a project with a timber curtain wall. We're looking at tapering the mullions, to make them less bulky. Basically, the top and bottom transom are less wide and we want the columns to follow that. See image attached (section).
Thought it would be simple to model with a void: model in place > curtain wall > void > cut void through existing curtain wall, but that doesn't work.
It's a really simple curtain wall with square profiles. Since we're in the construction phase I'd much rather amend current geometry/ maintain all tags that are associated with it, then model something new (generic model, columns, whatever).
Any suggestions?
Section view of desired tapered mullion in blue
