Tag wont load
Tag wont load
ben
Tag wont load
ben
I made a Note Tag for a sheet notes & schedule. It's supposed to work as a symbol. I load it into the project, no errors, says it loads, but then when I click for Symbols my Note Tag doesn't show up in the Type Selector. (2019)
Revit lives in the land of perfect and doesn't understand what construction is.
Ilic.Andrej
I had no problem with this family. Try to load it into another project and see if the problem is still there. I assume the issue is a conflict between loaded families, but that's just my guess... Anyway, the family you created is fine. Something in the project is causing the problem.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
ben
In the Project Browser under families it shows up, but it doesn't have the expandable + symbol next to it, and it wont let me drag it out into the project to place it either
ben
It does the same thing in a blank project too
Lakshman01
Hi @ben
As you can see the attached image. It's working properly. I think there is a bug in your project file. IMG_20200427_223602__01.jpg
Like @Ilic.Andrej  said try to load in any other project's files..
ben
Ok it was weird, but I got it to work. I loaded it into another project and used Transfer Single to load it into this one. Strange, but works...I guess
