tag skylight in floor plan
umbachdw
umbachdw
I have some skylights in a project that need to be tagged for the fenestration schedule. There will not be a reflected ceiling plan, so I need to tag them in the floor plan.  Is there anyway to do that since the skylight is above the cut plane? I can an underlay and add annotation lines easily enough to locate the skylights in plan, but Revit doesn't want to tag them if they are not in the view.
Alfredo_Medina
You could make the skylight show up in the floor plan by using a plan region with a different view range. But that might look a little confusing in your floor plan. However, on a second thought, after using the plan region you could override the visibility of the skylight to be dashed lines.
Another alternative si tag the skylight in another view, an elevation view or a roof plan.
Alfredo, thank you. I just spent an hour trying to tag my skylights on my roof drawing with no success.
Read your post about tagging in a different view. Changed to my elevations and it let me tag.
You are a star. Thank you.
