Tag parameter in schedule
shahin_kiyomarsi
shahin_kiyomarsi
How can I get this parameter from a room tag to show up in my project schedule.
lumbera_darwin
Hi @shahin_kiyomarsi ,
The "LOAD" parameter should be created as a "shared parameter".
Then in the project, go to Manage>Project Parameters and add the "LOAD" shared parameter and associate it as Rooms category.
Hope this helps.
Dar
If it is a calculated value label in the tag family then you can add the same calculated value field to the schedule and use the same formula (Area / Occupant Load Factor).
