tag/annotation orientation from linked model
LB_revit
LB_revit
Hi Everyone
I struggle with one specific issue. When I link a model and rotate it, all tags/annotations Doesn't follow the rotation of the model in the host... (see picture attached). Even if I select "Model orientation" in the source model.
Is there any way to align tags accordingly to the original model?
Here is the original model
And when i link and rotate it
I hope a formulate correctly my problem
Thanks a lot
Laurent 
Check Rotate with Component in Tag Family.
LB_revit
thanks alot, it works at least for the window and door tags! But I don't have these option for the room tag. I keep searching ^^
Thanks again it helps me alot
Laurent
