Tab bar gone
Tab bar gone
Message 1 of 13
Tab bar gone
I am not sure what have i done but i can't see the tab bar since recently. Helppppppp
Replies (12)
Message 2 of 13
Corsten.Au
Its on the FLY options bar...
Select any element ( or command ), and Revit will show corresponding options bar relevant to the command...
hope that helps..
Corsten
Building Designer
Message 3 of 13
First of all, thanks for reply. Unfortunately i do not get it, i am looking for the particular bar (refer to screenshot)
Message 4 of 13
Corsten.Au
Hi.
Open more than 1 view...
and type " WT " Window Tile...
Let me know if thats what you were looking for..
cheers
Corsten
Building Designer
Message 5 of 13
Once again thank you, Yes it does appear in different windows. However the "tab" function similar to the "tab" when we see while using google chrome or explore is still not appearing....
Message 6 of 13
Corsten.Au
Tab and Tile View Option ( This is available in 2019 ) , am sure you have Revit 2019....Tab and Tile View Option ( This is available in 2019 ) , am sure you have Revit 2019....
Corsten
Building Designer
Message 7 of 13
Any idea why mine do not have?
Message 8 of 13
Corsten.Au
Whats your Revit Version?
Its available only in 2019..
Corsten
Building Designer
Message 9 of 13
2017. A few days ago it was still working, few years ago when i was using revit 2015 the function is already there...
Message 10 of 13
Corsten.Au
Tabs were introduced in 2019...
am sure there's something else you are referring to..
View tab 2019View tab 2019Comparison with previous version .... since 2015Comparison with previous version .... since 2015
Corsten
Building Designer
Message 11 of 13
I remembered using it since 2015 with that function clearly. Nonetheless i guess it is alright since i can still work around it. Many thanks to your response!
Message 12 of 13
thachtoantrung
I want to hide it like yours, show me if you know pls!
Message 13 of 13
Hide what?
