Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
System families disappeared from own project template
2 REPLIES 2
marieHPAJL
302 Views, 2 Replies
Dear good helpers.
Most of the walls, all doors, windows, tags etc have disappeared from my otherwise very nice custom project template.
I don't know how to load system families. Does anyone know? And what has happened? In the standard metric template out of the box, everything seems to be normal.
2 REPLIES 2
in reply to: marieHPAJL
Probably Purged. You can use Transfer Project Standards to transfer from another open Project.
...any other content can be loaded into the project from any location (Insert Tab=>Load Family). If the idea is to keep it available to new Projects started, then save the Project, with all the loaded content, as a Template (RTE) - and then Start New Projects using that RTE.  .
marieHPAJL
in reply to: barthbradley
Thank you, @barthbradley
This has happened in a template I made myself. I will save it under another name and try to do as you describe.
