Synchronizing not saving current progress.
BMA-ADMIN
BMA-ADMIN
Working on this project with 7 other people so we have a Central and Local files. Anyway 1 staff member seems to be Synchronizing and then in the morning her project is always set back an hour prior to her last Synchronize.
Last Friday she completed this joinery piece, I checked it and we reloaded back into the project and synced to Central.
This morning the same joinery has been reset back an hour so it show as incomplete.
Any Ideas on this one?
Corsten.Au
Hi
While editing anything on central file, one needs edit access, workset should be editable or at-least
borrowed from particular workset..
sometimes while editing , Revit mentions ( Pop up warning ) the edits will be temporary cause workset either not editable or not able to borrow.. and the changes made stays temporary and not able to save to central..
that probably ending up that file to loose the work and go back to old saved status when saved to central...
do a testing, make some changes, try to save to central and check of other members can see that change
after reloading or saving to central..
Best luck.
Corsten
Building Designer
ennujozlagam
hello, check if the user has the same build like other user's and update if necessary and see if helps. thanks
