Synchronization
Synchronization
tstewart
Message 1 of 9
Synchronization
tstewart
THe Synchronization button is greyed out, so I can't sych or publish to the ACC cloud. How to change the status on the toolbar, so I can sych.?
Replies (8)
Message 2 of 9
vitorbortoncello
Try closing the model and reopening it from the ACC cloud. This often resets the connection and re-enables the "Synchronize" button.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 9
RSomppi
Is this a workshared model that resides on ACC or are you trying to make it one?
Message 4 of 9
tstewart
Older versions reside on ACC, so I need to make this one visible to consultants on ACC.
Thank you,
TS
Message 5 of 9
RSomppi
Your responce is not clear and lacking needed information.
Are you all set or do you still need help?
Message 6 of 9
tstewart
Thank you and the model says, "Cloud model" rather than "Workshare model' and is not allowing me to publish, or synch. Is there a way to convert the loud model to workshare?
Message 7 of 9
RSomppi
I'm fairly certain that in order for it to be a cloud model it is already workshared. Do you have worksets in it?
Message 8 of 9
tstewart
I need help. The Synch button on the toolbar is greyed out, so how to synchronize the latest drawings and share in ACC?
TS
Message 9 of 9
RSomppi
You said that in your first post. Please see my latest responce question.
