Symbolic lines do not show up as intended
Sahay_R
Mentor Mentor
Message 1 of 8
Sahay_R
When inserted into a 1/8" scale plan view, the symbolic line representation for these lockers does not show up as a hidden line. However, it does show up correctly when the view scale goes up to 1/4" or larger. How do we fix it?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Replies (7)
Message 2 of 8
The segment is too short. Use a denser line type.
Message 3 of 8
Sahay_R
Went down to 1/32" dashes and spaces. No go.
Rina Sahay
Message 4 of 8
Are the 1/8" and 1/4" plans under the same phase?
Message 5 of 8
Sahay_R
Yes. All under New Construction. I just changed the scale on the view that I was using to test the family.
Rina Sahay
Message 6 of 8
Message 7 of 8
Sahay_R
FOr some reason, 1/16" worked for me! So setting the linetype in the family was not enough? Needed to be present in the project as well?
Rina Sahay
Message 8 of 8
Project's always overrule families'.
