Switching Between Views Shortcut
Recently my operating software malfunctioned, upon reinstalling Revit the shortcut (Ctrl + Tab) is no longer functioning. When in the Keyboard shortcut menu (KS) there is no option to add a keyboard shortcut to the Switch Windows function. Is there a way to add this shortcut?
SteveKStafford
That is a Windows OS basic feature. Does it work in your browser? Open more than one tab and see if it switches between the tabs?
Steve Stafford
I am working on a Mac within Parallels, and am unable to verify that it works with the browser. The shortcut was working until I had to have the computered wiped and the OS reinstalled.
SteveKStafford
I don't use Revit that way. The OS you're running via the VM should have a default browser available to open to check. At this point, it sounds to me like a VM implementation/options issue rather than something specific to Revit.
Steve Stafford
See your problem solved here: https://kb.parallels.com/124069
