Swept Blend with non square profile
Message 1 of 14
I'm trying to make a family similar to below. I can do it as an adaptive family but I don't really know how to use the adaptive family. I am quite competent with Generic Model family creation however I don't know how to get the profile similar to the attached.
I need to do a swept blend with a profile that can be rotated at an angle to the path.
Anyone have any suggestions? I'm very confused so apologise if I have explained it poorly.
Replies (13)
Message 2 of 14
Think you can figure it out from the attached?
See also:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M...
Message 3 of 14
Thanks for the reply.
I may have explained it very poorly.
My issue is I want to stay away from an adaptive family because I want to nest this with other Generic model families. I was wondering if its possible to do a swept blend similar to the attached screenshot below.
BLUE being the profile (a basic square) and RED being the path of the sweep. As seen below, I need to keep the profile vertical however I want to create a parameter to adjust the "SKEW" angle.
Message 4 of 14
Why are you in an Adaptive Template then? Anyhow, you can create that Sweep Blend by pathing along a Ref. Line in a regular Template.
...wait a minute.  I misread you screenshot.  You'll need to cut your form with a Void Extrusion at both ends.
....is this what you are after?
Message 5 of 14
Man, you got some Escher sh*t going on here.
This?
Message 6 of 14
haha the geometry has been doing my head in for a while.
What you have there is what I come up with as well. But its not what i need.
This is the best way i can explain it:
(Thats also the reason I attached that adaptive family. To explain the geometry and work out if I could do that as a generic model)
Above.... a-a is the same level and b-b is the same level (constant)
Message 7 of 14
That is just a basic swept blend.
Message 8 of 14
YES! That’s it!
So the path is not straight and the profiles are offset?
Would it be possible for you to create that in revit 2021 and send over the file so I can investigate? I can do 2022 if you wish but would just have to download it from my suite.
thanks so much. Keen to see how it flexes
Message 9 of 14
RDAOU
Sounds more like
  • a line based extrusion w
  • 2xAngle parameters to tapper each end
Message 10 of 14
Okay then -- so we're back to what I showed you in Message #4.
Message 11 of 14
@Anonymous wrote:
YES! That’s it!
Here is a 2019 family.
Message 12 of 14
Ah! I see now.
Can you help me out with this one since you're on a roll now?
Message 13 of 14
Message 14 of 14
Thank you ToanDN!
That is the geometry I am after! Really appreciate the quick response on this.
