Sweep won't work on Roof
info
info
HI,
I'm trying to cut a void into as curved roof.
I can't select the void to use "Cut" tool when Edit in Place?
info
A simple void extrusion won't  cut the roof either?
info
Thanks.  I solved it!
You mean you modeled an In-Place Void and you can't use Cut Geometry to cut a System Family Roof with the Void?  You should be able to.  Post the file.
info
Yes.
That's ok, I was using a Sweep to cut not a Sweep Void...
But thanks for your post.
You could have still done it with a Solid. Instead of Cut Geometry, you would Join Geometry - and then hide the Solid Sweep Extrusion in the View. Viola! The Roof would be cut by the Solid just as if it were cut by a Void.
info
No worries.
