- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
HI,
I'm trying to cut a void into as curved roof.
I can't select the void to use "Cut" tool when Edit in Place?
HI,
You mean you modeled an In-Place Void and you can't use Cut Geometry to cut a System Family Roof with the Void? You should be able to. Post the file.
You could have still done it with a Solid. Instead of Cut Geometry, you would Join Geometry - and then hide the Solid Sweep Extrusion in the View. Viola! The Roof would be cut by the Solid just as if it were cut by a Void.
