- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This one might sound tricky and a bit confusing, but I'll try my best to explain.
We just bought a Total Station, and we are going to try it out on a small job for a trial run, and I'm trying to get everything loaded into the tablet so it's ready to go. I exported the Revit floor plan to dwg, and imported it to the tablet for the Total Station (Unit: Inches). So far, so good. I get the control points from the surveyor (7 Control Points) for the 15' setbacks from the foundation walls at the building's corners (Units: Int Feet, Delimiter: Comma). Now the coordinates setting is where it seems a bit confusing to me; my options are: XYZ(NEH), NEH, ENH, XYH(NEH), XYZ(ENH), YXH(ENH), and YXZ(NEH). The surveyor told me that in the txt file the information is point, northing, easting, elevation, description. I have literally tried importing the control points in for every coordination setting that is in that order XYZ(NEH), NEH, XYH(NEH), and YXZ(NEH); I have also tried importing all of them in every combination trying to use different units as well (Int Feet, US Feet, and Inches). No matter what settings I use the result is always the same, even though all 7 control points are loaded only 1 point shows up on the screen and the floor plan nowhere to be found, or appears to be a tiny speck that I cant even zoom in enough to see it.
I called the manufacturer of the total station and he said that the surveyor might be using a State Plane Coordinate System, which I had never heard of because I'm not a surveyor and I don't pretend to know the systems and methods that they use. I emailed him & asked if it was based on a State Plane Coordinate System; he emailed me back and said, "They are close to UTM 14N but not perfect because a ground scale was applied. They may be off a quarter inch from UTM14N." I have no idea what that means, I Googled it and it says it has something to do with NAD83. I also don't know what that means either, I'm assuming it's a method of surveying, but I don't plan on taking up surveying as a hobby, so is there just a way to get his points to work with Revit, my dwg export, or import on the tablet so I don't have to do some crazy survey marker control point conversion?
Control Point txt file is attached if it helps at all
Revit lives in the land of perfect and doesn't understand what construction is.
