Message 1 of 13
Survey 3D points dwg import wont create topo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
The surveyors output is from Autocad LT and contains points as well as separate level annotations. The points are all showing XYZ
The surveyors originating dwg has no contours just points, annotations and lines.
When I import either as linked or CAD import the points are visible in 3D. I have tried:
- standard toposurface > select import instance - checking only the points layer comes up with "The surface must have at least three distinct Points" error.
- explode the import - the points all disappear
- separating out all the dwg and import only the points (no text, lines or separate levels)
- exporting from the dwg by command dataextraction into a csv list - this results in a horrible pattern of points and mesh lines all in one vertical plane (tried switching the workplane = exactly the same). There are about 600 points in all
- the levels are text objects with xyz attributes - importing these similarly not recognised
Any ideas - never had this before. Attached the originating dwg
